TwinTurbo.NET: Nissan 300ZX forum - Re: OEM waste gate arm length different L/R?
Subject Re: OEM waste gate arm length different L/R?
Posted by nzryan on September 12, 2013 at 8:36 PM
  This message has been viewed 158 times.
In Reply To OEM waste gate arm length different L/R? posted by wild_maxx on September 12, 2013 at 07:11 PM
Message That last picture is the closest (although probably a little too much), the wastgate actuator is meant to have some tention on the wastgate ~pulling~ it closed when its attached, so it is normal to have to pull the actuator arm out a bit to fit it onto the wastgate.
Clocking of the housings have quiet an effect on the arms, maybe that us your issue.
But I would certainly recommend doing a pressure crack test with a boost gauge BEFORE you fit the turbos back on the motor.
